Unity connection OS install issues
Sep 6th, 2007
I'm coming across issues on the MCS7825-H2-UC1 for Untiy connection, shipped with OS pre-installed. When I booted the server up the first time, it started WinXP and prompted me through the setup to install 2003 server. After it ghosted the image to the drives and self rebooted, I end up at a blank screen after the startup boot tests (at the point Windows should be loading). There is no drive activity and just sits at a blank screen. I tried reimaging using the Unity connection platform config disk (DL320G4 v 2.0.0.4), which it goes through the 1 1/2 hour process of ghosting the image, but it does the same thing after it reboots, it ends up at a blank screen. During startup, it detects the Raid 1 and states the drives are healthy (2 80G SATA) and detects 1 logical drive. I also went in the raid manager during startup to verify and it looks to be setup correctly. Any suggestions on how to fix this issue? Thanks.
