PIX 515E
Sep 6th, 2007
When I try to initiate a vpn with ping of telnet xxxxx port xxx then the VPN tunnel doesn?t get established. If I use an application that uses the same port then it works.
didyap Wed, 09/12/2007 - 09:54
Check again if you have defined telnet to the specific port as an interesting traffic for the VPN configuration. The application you are using may be using some additional packets that are getting matched as interesting traffic and so the tunnel comes up.
