Wireless Wake on LAN
Sep 6th, 2007
I have a need to be able to Wake machines using wireless lan. Is this possible with any Cisco products or even non Cisco products?
Ed
Overall Rating: 4 (1 ratings)
edw Thu, 09/06/2007 - 12:27
Thanks but I ve dona lot of leg work - I was hoping that someone might have experience in this area.
The Intel card is for never laptops, I'm wanting it for desktop pcs
Ed
ericgarnel Fri, 09/07/2007 - 05:20
  • Gold, 750 points or more
Ok, I am going out on a limb here....
Assuming that the client PC has wake on Lan [WOL] enabled in the bios and the wireless nic supports it, are you allowing broadcast traffic (udp) to get to the subnet where the machines in question live? WOL is typically udp and any routers in the path would have to be configured to allow it or have the option in their dhcp scope (if the router is serving up dhcp).
Trending Topics - Security & Network
