ISDN PRI incoming calls problem
Sep 6th, 2007
Guys,
I am having a bit of a trouble here, i am able to make out going calls for all the extensions, but on an inbound call from out side on any of the PRI numbers, i get a dial tone after dialing, after which if i dial the extension number, the extension rings other wise not can any one please help me out to resolve this issue i am also attaching the config file.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Thu, 09/06/2007 - 10:02
  • Hall of Fame,
    Founding Member
Your DP 1 is not matching the called number:
dial-peer voice 1 pots
incoming called-number 1..
Change to what you see in "debug isdn q931" and the call will accepted.
I don't know if you have DID and if so what "dialplan-pattern" is needed under telephony-service. That is also needed to ring the extensions directly from outside.
aamirdhedhi Thu, 09/06/2007 - 10:11
thanks for ur reply i had tried using 1.. in dial peer but it did not work
i also configured dialplan patter
the DID range is from 8020100 to 8020299
Paolo Bevilacqua Thu, 09/06/2007 - 10:36
  • Hall of Fame,
    Founding Member
So configure incoming called-number 8020...
You can remove the port from the incoming DP, it is not used.
and "dialplan-pattern 1 8020... extension-length 3"
As an appreciation to those providing answers, please rate useful posts using the scrollbox below!
Paolo Bevilacqua Thu, 09/06/2007 - 23:38
  • Hall of Fame,
    Founding Member
Then just use .. for incoming called-number in the DP that has direct-inward-dial. Or take debugs isdn q931 with term mon and place the correct number.
anderson-david Fri, 09/07/2007 - 00:16
  • Bronze, 100 points or more
put the cmd "direct-inward-dial" under your POTS dial peers this should stop the secondary dial tone, also how many digits is your service provider presenting BT present 6 by default so unless you have asked for only 3 to be presented you will need a translation pattern to change the incoming 6 digits to 3.
I hope this helps
aamirdhedhi Fri, 09/07/2007 - 05:17
Dear Anderson
the number provided by the telco is 8020222 the range i have been given is 8020100 to 299.i hav configrued the extensions starting from 100 to 135 i have arleady put direct-inward-dial. can u tell me how to do the translation.
Cheers
aamir
Paolo Bevilacqua Fri, 09/07/2007 - 05:36
  • Hall of Fame,
    Founding Member
The command under telephony-service is:
dialplan-pattern 1 8020... extension-len 3
This assumes telco is sending 7 digits for called number thing that you can verify with "term mon" and "debug isdn q931".
aamirdhedhi Fri, 09/07/2007 - 23:37
Dear the following is the result of debug isdn q931
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98388
Exclusive, Channel 8
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '048850447'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '0122'
Plan:ISDN, Type:Unknown
Sep 8 07:20:15.386: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9
D52
Sep 8 07:20:15.386: ISDN Se0/0/1:15 Q931: TX -> CONNECT pd = 8 callref = 0x9D5
Sep 8 07:20:15.846: ISDN Se0/0/1:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0
x1D52
Sep 8 07:20:15.846: ISDN Se0/0/1:15 **ERROR**: call_progress: DEV_CONNECTED VOI
CE ERROR: Bearer capability not available(0x3A): b channel 7 call id 0xF8
can u please go throug and help me
Paolo Bevilacqua Sat, 09/08/2007 - 01:50
  • Hall of Fame,
    Founding Member
Telco is passing four digits. Use
"incoming called-number 0..." and
"dialplan-pattern 1 0... extension-length 3".
Paolo Bevilacqua Sun, 09/09/2007 - 08:30
  • Hall of Fame,
    Founding Member
Thanks for the nice rating and good luck!
