cisco 851w can not interconnect wireless VLAN
Sep 6th, 2007
hi evrybody
i have problem with my cisco 851w
for example :
i whant to access from client in vlan1 to in client in vlan2.
this is all my configuration please can someone help me thanks
version 12.4
service config
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service sequence-numbers
hostname 851w
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
enable secret 5 $1$22PV$R9ivAlMbvTiy9hjLdyLph.
enable password 7 060506324F41
no aaa new-model
o aaa new-model
resource policy
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
ip subnet-zero
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 10.0.2.1
ip dhcp excluded-address 10.0.3.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool sdm-pool1
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
ip dhcp pool sdm-pool2
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
ip dhcp pool sdm-pool3
network 10.0.3.0 255.255.255.0
default-router 10.0.3.1
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name boomerangpharma.com
bridge irb
interface FastEthernet0
shutdown
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
description Cisco Open
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
no ip route-cache
broadcast-key vlan 3 change 10
broadcast-key vlan 2 change 10
encryption vlan 3 key 1 size 40bit 0 1234567890 transmit-key
encryption vlan 3 mode wep mandatory
ssid atmdata
vlan 1
authentication open
ssid atmvlan2
vlan 2
authentication open
ssid atmvlan3
vlan 3
authentication open
authentication network-eap eap_methods
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2462
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
no cdp enable
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Vlan1
description intvlan1
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description intbvI1
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface BVI2
ip address 10.0.2.1 255.255.255.0
interface BVI3
ip address 10.0.3.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 3 protocol ieee
bridge 3 route ip
Anonymous (not verified) Wed, 09/12/2007 - 11:17
There is no VLAN interface configuration for VLAN 2 and VLAN 3. Ensure that these are configured.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
