Syslog and FXO card
sorinbadea
I have a 2811 with one four-port FXO card; 4 POTS lines are connected to it. Syslog is configured on the router, sending traps (debug level) to a host. For some reasons, I do not get any info in syslog form the card; so making or receiving a call sends nothing. Any ideas?
Thanks, S.
paolo bevilacqua
This is the normal, making and receiving calls do not generate syslog output. If you want output, either enable some debug permanently, or use a radius server for exact accounting.
paolo bevilacqua
