cisco_lad2004 Thu, 09/06/2007 - 12:12
assuming you have a looped topology, a root bridge will be the root of ur spanning tree topology.
so effectively it will teh switch where u are guaranteed to have both ports in forwarding state.
if you do not configure it, a root bridge will be elected based on Bridge ID.
the benefit of choosing it urself is that you dictate how spanning tree should be.
Sam
