acomiskey Thu, 09/06/2007 - 12:20
  • Green, 3000 points or more
Did you generate a key?
ca gen rsa key 1024
mattiaseriksson Thu, 09/06/2007 - 13:29
  • Bronze, 100 points or more
Are you trying to connect from the outside? You are only allowing ssh on that interface.
And if you have changed hostname or domain you need to generate new rsa-keys.
elovelace256 Thu, 09/06/2007 - 13:33
Yes I am connecting on the outside, and generated new rsa keys. I don't know what else would be blocking it.
Anthing in the access lists?
mattiaseriksson Thu, 09/06/2007 - 13:47
No.
Enable debugging with 'debug ssh' and observe the output.
a.alekseev Fri, 09/07/2007 - 00:25
  • Gold, 750 points or more
let's try again
conf t
ca generate rsa key 1024
ca save all
