Customize IP used by DFM Reachability Process
Answered Question
Sep 6th, 2007
We have quite a few devices, which have been added into DFM using an interface towards our network (E.g. Fa0/0). In some cases we do not advertise the Network\Subnet configured on other interfaces (E.g. Fa0/1) in our network, so that interface IP is un-reachable from DFM Server.
Even though DFM Server knows that device by it Fa0/0 IP, it still also tries to Poll the Fa0/1 IP and labels the device as un-reachable.
Is there a way to fix this ? Without having to advertise those un-reachable IP Subnets into the network.
Naman
Correct Answer by Joe Clarke about 9 years 4 months ago
This is a known bug, CSCsb48643. The workaround is to unmanage those interfaces in DFM, but then you will also lose operationally down events for them. If you open a TAC services request, and reference this bug, a script can be provided that offers a better workaround. This bug has been fixed in LMS 3.0 by offering a GUI way to disable ICMP probes for certain interfaces.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Thu, 09/06/2007 - 15:40
mnlatif Tue, 09/11/2007 - 12:12
Is it possible to see the list of IP addresses that were set as Un-Managed earlier by the script ?
I am also assuming that re-running the script with new IP Address range will not re-initialize the list (and remove the earlier added IP) ?
I starting using this script, which mostly works but I noticed a few times that some IP addresses, which were set to Un-managed, started to show-up in the Alerts again. This usually happened, when I re-ran the script with new IP range etc.
\\ Naman
Joe Clarke Tue, 09/11/2007 - 22:04
You can get the managed state of all IP instances by using the following commands:
NMSROOT/objects/smarts/bin/dmctl -s DFM getInstances IP
Then, for each IP instance:
NMSROOT/objects/smarts/bin/dmctl -s DFM get IP::::IsManaged
For example:
NMSROOT/objects/smarts/bin/dmctl -s DFM get IP::IP-10.1.1.1::IsManaged
Re-running the script on a different range should not affect those addresses that have already been unmanaged.
