ATM Configuration
Sep 6th, 2007
Hello Guys,
We are currently migrating our circuit from Frame-Relay to MPLS. Our corporate will be on a t3 connection acting as a hub to all the branch office. The PTE from at&T that I've worked with sent me the information below. I'm not quite sure how to go about configuring the ATM interface which will be connected to AT&T MPLS backbone. Currently the ATM interface is configured below.
interface ATM1/0
mtu 1500
bandwidth 9000
ip address x.x.x.x x.x.x.x
ip nbar protocol-discovery
ip hold-time eigrp 1616 60
ip authentication mode eigrp 1616 md5
ip authentication key-chain eigrp 1616 SBC_MPLS
atm framing cbitplcp
no atm ilmi-keepalive
pvc 15/34
protocol ip x.x.x.x broadcast
vbr-rt 9216 5000 144
oam-pvc manage
oam retry 3 3 10
encapsulation aal5snap
Information from AT&T for new MPLS.
Speed: T3
Line Coding / Framing: CBIT/B3Z3
Serial Encapsulation: PPP
Timing: Net/Line
Routing Protocol: BGPv4
DSU Bandwidth: 44210
AT&T AS#: 7018
mheusing Fri, 09/07/2007 - 03:58
are you sure it is ATM connecting you to AT&T? The info says PPP and I would assume they do not mean PPP over ATM but pure PPP as Layer2 protocol.
Can you check again, what the AT&T requirements are, as this could mean your ATM interface cannot be used anymore.
Regards, Martin
