Warning message
CME BACD script wont route to hunt groups
Sep 6th, 2007
I just activeated the CME BACD TCL script. It is answering calls, playing prompts and allowing users to use the dial_by_extension feature however I can not get the script to route to a hunt group.
I have two hunt groups setup. When a caller selects an option from the main menu that is associated with a hunt group they hear MOH for about 10 seconds and then the system plays a message that says "sorry we are unable to complete your call" (or something like that).
The hunt groups work if you dial them manually. Do the users need to do anything else to make their phones available? DND is not on.
Here is the config: (this is a CME version 124-11XJ ? integrated with Unity 5.0)
application
service aa flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 1
param handoff-string aa
param dial-by-extension-option 1
paramspace english language en
param max-time-vm-retry 1
param aa-pilot 6099
param max-extension-length 4
paramspace english location flash:
param welcome-prompt _bacd_welcome.au
param voice-mail 1000
param max-time-call-retry 250
param service-name queue
service queue flash:app-b-acd-2.1.2.2.tcl
param aa-hunt2 1111
param aa-hunt3 2222
param queue-len 10
param aa-pilot 6099
param queue-manager-debugs 1
param number-of-hunt-grps 4
service load aa
dial-peer voice 1000 voip
description Auto Attendant
service aa
destination-pattern 6099
session target ipv4:10.10.10.10
incoming called-number 6099
dtmf-relay h245-alphanumeric
codec g711ulaw
ephone-dn 1
number 6000 secondary 6000
label Test 1
description Test 1
name Test
call-forward busy 1000
call-forward noan 1000 timeout 10
hold-alert 30 originator
ephone-dn 2 dual-line
number 6001 secondary 6001
label Test 2
description Test 2
no huntstop
ephone 1
video
mac-address 001D.4561.4C29
type 7941
button 1:1
pin 1234
ephone 42
video
mac-address 001D.4561.5852
type 7941
button 1:2
pin 1234
ephone-hunt 1 sequential
pilot 1111
list 6000, 6001
timeout 10, 10
display-logout DND / Logged Off
ephone-hunt 2 sequential
pilot 2222
list 6001, 6000
timeout 10, 10
Overall Rating: 4 (1 ratings)
craiglcve Fri, 09/07/2007 - 09:32
Here is a working config. You dont need the param aa-pilot 6099 under the service queue. Also do a dir on the router and make sure that you have all the following audio files specifically the en_bacd_music_on_hold.au file
ccme#dir
25 -rw- 75650 Nov 29 2006 16:30:06 -07:00 en_bacd_allagentsbusy.au
26 -rw- 83291 Nov 29 2006 16:30:06 -07:00 en_bacd_disconnect.au
27 -rw- 63055 Nov 29 2006 16:30:06 -07:00 en_bacd_enter_dest.au
28 -rw- 37952 Nov 29 2006 16:30:06 -07:00 en_bacd_invalidoption.au
29 -rw- 496521 Nov 29 2006 16:30:08 -07:00 en_bacd_music_on_hold.au
30 -rw- 123446 Nov 29 2006 16:30:08 -07:00 en_bacd_options_menu.au
31 -rw- 42978 Nov 29 2006 16:30:08 -07:00 en_bacd_welcome.au
Here is my config. I break my dial peers up into two seperate dial peers but it works both ways.
application
param queue-len 10
param aa-hunt1 2005
param aa-hunt2 2006
param number-of-hunt-grps 2
paramspace english index 0
param dial-by-extension-option 3
param max-time-vm-retry 2
param aa-pilot 2004
param second-greeting-time 30
param call-retry-timer 5
param max-time-call-retry 180
param voice-mail 7000
dial-peer voice 201 voip
service aa
incoming called-number 2004
codec g711ulaw
no vad
dial-peer voice 202 voip
destination-pattern 2004
session target ipv4:192.168.0.1
codec g711ulaw
no vad
pilot 2005
list 2001
timeout 120
pilot 2006
list 2000
joelalli123 Fri, 09/07/2007 - 12:21
I copied your working config but it doesn't work for me. I have the exact same problem. I am starting to think this is a bug. Has anyone successfully got this to work with 124-11XJ? What version are you running?
The only change I made to your configuration was the voice mail number and I added an audio prompt (which works fine). Here is the new config and debug:
application
param aa-pilot 2004
param queue-len 10
param aa-hunt1 2005
param aa-hunt2 2006
service aa
codec g711ulaw
no vad
session target ipv4:10.2.70.1
codec g711ulaw
no vad
pilot 2005
list 6000
timeout 120
debug voice application script:
Sep 7 13:04:40.562 PST: //179//TCL :/tcl_PutsObjCmd: TCL AA: ++ Playing Welcom
e Prompt and options menu ++
*Sep 7 13:04:40.822 PST: //179//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM insi
de Tcl modulespace. code=1 code=ERROR
*Sep 7 13:04:40.822 PST: TCL script failure
Result:
syntax error in expression " ([info exists msg_array(op
tionIDX)] == 1) && ([info exists "
*Sep 7 13:04:40.822 PST: TCL script failure errorInfo:
syntax error in expression " ([info exists msg_array(opt
("if" test expression)
while compiling
"if { ([info exists msg_array(optionIDX)] == 1) && ([info exists msg_array(callS
tate)] ==1)\
&& ([info exists msg_array(keepTime)] == 1)} {
if {[..."
(compiling body of proc "QueueManager.Get", line 32)
invoked from within
"QueueManager.Get"
paolo bevilacqua Fri, 09/07/2007 - 12:29
  • Hall of Fame,
    Founding Member
Joe,
you are getting syntax errors in the cisco-provided TCL. This is not normal, are you positive about the integrity of the script ?
(I haven't checked the exact line and why the error)
joelalli123 Fri, 09/07/2007 - 13:17
I have uploaded the scripts 3 different times and they were obtained from 3 different sources. They should be fine.
craiglcve Fri, 09/07/2007 - 13:20
My lab CME's are Version 12.4(4)XC5 and 12.4(4)XC6.
I would try loading another version of BACD on the router. Either BACD 2.1.0.0 or BACD 2.0.1.0
Then rebuild your aplication using the older version of bacd...
service aa flash:app-b-acd-aa-2.1.0.0.tcl
service queue flash:app-b-acd-2.1.0.0.tcl
also did you verify you have the en_bacd_music_on_hold.au in flash? There was a bug related to that audio file missing and calls failing.
paolo bevilacqua Fri, 09/07/2007 - 14:04
  • Hall of Fame,
    Founding Member
I routinely use 2.1.2.3 to which I even made some mods, works fine. Most definitely you should not ever get syntax errors from scripts.
joelalli123 Thu, 09/13/2007 - 09:53
Its working now. I made the mistake of extracting the BACD files first then moving them to flash instead of using the archive tar /xtract method. Thanks for your help
