Uploading configuration files to MGX8850
Sep 6th, 2007
Hello all,
I need to upload customer configuration files to MGX8850. I am new to the WAN switching and I need a good link that help me upload the configuration files from a FTP or TFTP?
Also I need some a good link to IMA on the MGXs. Thank you very much for your help.
moelsaye Fri, 09/07/2007 - 05:22
Hello Mohammed,
The boot firmware revision for the PXM45B is 5.2(10.201)
mohammedmahmoud Fri, 09/07/2007 - 11:15
Hi Mohamed,
You'll find in this document everything related to AUSM and IMA:
As for restoring the configuration for the whole MGX use the following steps (if you are talking about a single customer configuration you must do it manually or via CWM):
Restore the configuration file from the CWM (or the backup server) via tftp.
Use tftp put command on the CWM to the CNF folder of the MGX (ex: CNF/.zip)
start to restore the configurations using "restoreallcnf -f "
You'll find all the relevant documents for MGX 8850 PXM45 in this url:
Mohammed Mahmoud.
