Problem with Cisco Router 1721
Sep 6th, 2007
Dear All,
I would like to ask you,I had router 1721 and add one module wic-1enet.So wic-1enet connected to Wan interface and int fas0/0 connected to Lan.my connection used speed 1 MB by fiber optic but when access internet it slow.My question is :
1-How can i know the status on router?
2-How can i know the process's router?
3-How can i troubleshooting?
best Regards,
Rechard
spremkumar Thu, 09/06/2007 - 21:26
hi
show ip int brief
which you use to view the interfaces available and the status of those interfaces.
show interface ethernet x/x
under which you can verify the errors / utilisation etc.,
show logs (if u hve enabled logging)
which can give u a fair idea on the error logs etc.,
show processes cpu
to identify the process running with the % utilisation of CPU..
regds
