Logging snmp linkdown/linkup 3750's
Sep 6th, 2007
I must be having a brain sludge day.
Senario
2 x 3570's (stackmembers) at location A
2 x 3570's (stackmembers) at location B
they are connected via 2 trunks in a etherchannel group.
The question is for command
snmp [authentication |
coldstart | linkdown |
linkup | warmstart]
I'd like to only be notified of the up/down status on the trunked interfaces only and not of any of the other interfaces configured as switchport access.
Thoughts..Thanks
glen.grant Fri, 09/07/2007 - 01:01
  • Purple, 4500 points or more
Make sure you have " no snmp trap link-status " on all user access ports . Not sure if that is the exact syntax but its close just use your tab key for the correct commands.
