Help with console server
andrey.v.tyurin
Hi, ALL!!!
Friends, I have a problem with my Cisco Router 2610XM. I configured it as Console Server with ASYNC module. And all my Cisco device works perfectly, I mean that it's console port connected with ASYNC module on 2610, and now my company buy HP ProCurve and I want to connect it to my Console Server. I find pin-out of
console port ProCurve and make a adapter db-9 rj-45 and connecting it to 2610 but it is not worked.
In pin-out of ProCurve said that "Data Terminal Ready" "Data Set Ready" does not used.
Help to connect Cisco with ProCurve, my
brain is broken!!
akemp
Level 5
Level 5
Thats why you should only use genuine Cisco equipment! :)
Procurves use two different pinouts for thier console conections "Straight Through" RS232C serial (pin 1 to one, 2 to 2, etc) AND cross-over aka "null modem" RS-232C serial.
Why not a linksys? Did the HP rep stop by purchasing handing out free pens ?
My chief by HP because his friend works in that (HP) company. :))
In HP ProCurve 5406 pin-outs of console connector is "null modem" and with computer works good, but with 2610 no.....
