switchport mode access
Sep 7th, 2007
Hello
I need little help, becouse I don t understand when I configure port security on switch, do I need to use
switchport mode access and then
switchport port-security something
or I can use just 2 line,
when I should use first line
thx
Overall Rating: 4.5 (2 ratings)
juergen-fischer Fri, 09/07/2007 - 00:26
switchport mode access may answer an expert please.
Talking about port-security from my point of view you need an explicit line
beside the other commands
switchport port-security something1
switchport port-security something2
Otherwise port security is configured but not enabled.
Juergen
ankbhasi Fri, 09/07/2007 - 00:27
  • Cisco Employee,
Hi Friend,
By default switchports are in dynamic desirable mode and port security can only be configured on static access ports or trunk ports. A secure port cannot be a dynamic access port.
That is the reason it is required for you to configure 1st line and then come down to 2nd line of your config.
Ankur
*Pls rate all helpfull post
