Blocking HTTP, Allowing POP3
Sep 7th, 2007
We have a Cisco Pix 515E firewall. We would like to restrict a workstation from serving the Internet (HTTP) but allowing it to use the POP3. Can someone guide us on how to do it?
rajbhatt Fri, 09/07/2007 - 01:59
Ur requirement is not clear .
Is it that u want that machine to access only outbound pop3 and restrict outbound hhtp
If that isthe case :
u can try these :
nat (inside) 1 x.x.x.x 255.255.255.255
global(outside) 1 interaface
access-list abc deny host x.x.x.x any eq http(to check the hit counts)
access-list abc permit host x.x.x.x any eq pop3
access-gr abc in interface inside
Raj
tstay-205 Sun, 09/09/2007 - 17:18
I want to restrict the machine from surfing the Internet, but allow them to receive email through POP3...
So do I just need to replace the x.x.x.x with the IP address?
And where do I enter these codes?
Thank you.
