E1 Software loop
Sep 7th, 2007
I have a VWIC-2MFT-E1 on a 2800 router.
I have to set up a software loop on the router to check the two E1 links (channelized). Would someone know how to set up a soft loop to test the E1 links.
Regards.
Overall Rating: 3 (2 ratings)
paolo bevilacqua Fri, 09/07/2007 - 02:21
  • Hall of Fame,
    Founding Member
All the loop command are configured under controller. You can loop the line toward the circuit, the router, etc.
cisco_lad2004 Fri, 09/07/2007 - 02:42
  • Gold, 750 points or more
I vaguley remember the commands, try below:
Controller E1 X/Y
E1 N loopback local
Sam
deephazz02 Fri, 09/07/2007 - 09:00
Conf t > Controller E1 X/Y/Z > loopback local line
