CSS11506 SSL offloading
Hi ,
I have been going through the document you gave me and was wondering if you could clarify some points for us. In an excerpt from the document you sent me:
content rule
backend-server 10
backend-server 10 type backend-ssl
backend-server 10 ip address
backend-server 10 port 86 _ must match port configured in the service
backend-server 10 server-ip
backend-server 10 server-port 443 _ must match HTTPS service port running on the real server
backend-server 10 cipher rsa-with-rc4-128-md5
backend-server 20
backend-server 20 type backend-ssl
backend-server 20 ip address
backend-server 20 port 86
backend-server 20 server-ip
backend-server 20 server-port 443
backend-server 20 cipher rsa-with-rc4-128-md5
Do you perhaps have an example where the SSL session terminates on the CSS and clear text HTTP is run to the Web Server.
As from what I can see the example excerpt I have above is for HTTPS to the backend servers.
Many thanks
Hi Gilles,
Thank you for your input. I was hoping you could clarify an issue for me. I have managed to export a test certificate off a test IIS server it is a .P7B file. I have copied this file onto the CSS. How do I deal with the key pair ? How do I import the key and associate it with the certificate.
Thanks for your assistance
