About web authentication.
Answered Question
Sep 7th, 2007
I want to configure a switch port for IEEE 802.1x authentication with web authentication as a fallback method.
Can someone provide a valid configuration example?
Only web authentication doesn't work!
Switch#sh run
Building configuration...
Current configuration : 3012 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
aaa new-model
aaa authentication login default group radius
aaa authentication login line-con none
aaa authentication dot1x default group radius
aaa authorization auth-proxy default group radius
aaa session-id common
switch 1 provision ws-c3750-48p
system mtu routing 1500
ip subnet-zero
ip domain-name cisco.com
ip admission name rule1 proxy http
dot1x system-auth-control
fallback profile fallback
ip access-group policy1 in
ip admission rule1
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
switchport access vlan 142
switchport mode access
interface FastEthernet1/0/47
dot1x pae authenticator
dot1x port-control auto
dot1x fallback fallback
interface Vlan1
no ip address
shutdown
interface Vlan142
ip address 10.1.254.1 255.255.255.0
ip classless
ip access-list extended policy1
permit udp any any eq bootps
deny ip any any log
radius-server attribute 8 include-in-access-req
radius-server host 10.1.254.187 auth-port 1645 acct-port 1646 key secret
radius-server source-ports 1645-1646
radius-server vsa send authentication
control-plane
line con 0
line vty 5 15
end
Correct Answer by scadora about 9 years 5 months ago
Try adding this:
ip device tracking
Also, if you want your web-auth users to be able to use DNS to resolve URLs, you probably want to add something like this to policy1:
permit udp any any eq domain
Remember you'll have to wait until 802.1X times out (90 sec by default) for Web-Auth to kick in.
Shelly
Overall Rating: 5 (1 ratings)
Correct Answer
scadora Fri, 09/07/2007 - 08:12
Try adding this:
ip device tracking
Shelly
andrea.meconi@c... Mon, 09/10/2007 - 00:59
Many thanks for your help Shelly!
Do you known how to personalize the authentication proxy login page?
Andrea.
andrea.meconi@c... Mon, 09/10/2007 - 05:43
Shelly,
if you want you can use the "ip admission auth-proxy-banner" command to add a banner.
Bye.
Andrea.
scadora Mon, 09/10/2007 - 07:03
Hi, Andrea.
Unfortunately, personalization is not currently supported. But tell your Cisco account team you want it! They should advocate for you.
Shelly
