QoS design difference between Auto qos and cisco SRND
okuehn
we are going to roll out a cisco VoIP solution. our access layer switches are catalyst 3750 with advancedipservices IOS image, we use cisco 7940 ip phones.
actually we are struggling whether to use auto-qos configuration or following the cisco design guide "Enterprise QoS Solution Reference Network Design Guide Version 3.3"
i thought the configuration would be pretty the same but we found the following differences:
interface FastEthernet1/0/5
description IP PHONE CONFIGURED WITH AUTO QOS
switchport access vlan 70
switchport voice vlan 71
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
end
interface FastEthernet1/0/6
description IP PHONE CONFIGURED WITH SRND
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
mls qos trust cos
why is the auto qos interface missing the "priority-queue out" command? i think this turns queue 1 into a LLQ queue?
what is the reason for the different bandwidth allocations of the 4 shared queues?
10 10 60 20 compared to 1 70 25 5
one last question: cisco recommends to classify and mark traffic as close as possible to the device. if we have to classify an application according to layer 3 ip/port information, do we have to place an inbound policy-map to the layer2 access switch ports of the PC's ?
or should we keep our current configuration of marking traffic at the WAN aggregation routers by using NBAR?
many thanks in advance!
5 Replies 5
szahid
Level 3
Level 3
Pls see inline .
[Salman]
This has been true for auto-qos on 3750 since day 1. Auto-qos on a 3750 ( and for that matter 3560 , 2970 and 2960 ) will never enable the priority-queue out. That command does convert the Egress queue # 1 into a PQ.
[Salman]
Its a possibility that SRND is written for a different code. The whole idea is to give the maximum bandwidth share to a queue to which your data traffic is mapped ( dscp = 0 ). If your data is mapped to queue 2 , then go with the number 1 70 25 5 and if your data is mapped to queue 3 , then go with 10 10 60 20. You can check which queue dscp(s) map to by using the command " show mls qos maps "
[salman]
Just because a port is L2 will not restrict you from classifying the traffic based on L3 information. All switches these days have the capability of classifying traffic based on several different types of criteria including L3 info , dscp , vlan etc. And if the switch allows you to do that , it will be a good idea to move the classification to the edge.
thanks
Salman.
Hi Salman, thanks for your reply.
following cisco's approach for using PQ/LLQ on real time traffic like voice, would you suggest to convert egress queue 1 into a PQ and enable priority queuing on the switch interfaces?
after looking the cos/dscp-queue mapping of Auto-Qos and SRND i understand the differences in the share queues: according to SRND, Q2 representing the Critical Data queue, Q3 representing the Best Effort queue (dscp/cos=0), and Q4 representing the Scavenger/Bulk queue. whereas in auto-qos the critical data is Q3 while besteffort and bulk remain both in Q4. so the two approaches utilize 60/70 percentage of the bandwidth for critical data, while only 20 percent is assigned to besteffort class. this sounds reasonable and seems to be pretty compareable.
however, i would suggest cisco to implement their default/auto-qos configuration according to their own best practice design guides.
thanks, Oliver
"however, i would suggest cisco to implement their default/auto-qos configuration according to their own best practice design guides. "
Consider:
Best practices often evolve, so this also raises the question should the Auto-Qos change with new code releases?
Also, Auto-QoS, I think, is provided as an easy method to implement some QoS. Whatever it does, it's unlikely one size will fit all.
yes, i've just installed 12.2(40) and configured auto qos cisco-phone on fe port. cisco has included the "priority-queue out" command in their current auto qos feature!
now the auto qos configuration correspond to their SRND.
they further unified their cos-dscp mapping from
mls qos map cos-dscp 0 8 16 26 32 46 48 56
to
mls qos map cos-dscp 0 8 16 24 32 46 48 56
thanks!
