H.323 communication with CCM
AJAZ NAWAZ
Level 5
Level 5
When a h.323 gateway receives inbound call from pstn and a voip dial-peer is matched, the call is forwarded to CCM. If the number forwarded to CCM is a know DN, is there any additional config/settings required to make the call succeed?
Can CSS's have any impact on inbound externally originated calls?
thanks
Ajaz
mchandak
Level 7
Level 7
CSS plays the same role as any phone trying to call. So, u will have to configure CSS on the Gateway such that the Gateway has access to the Partitions assigned to the DN
From which configuration screen can you add a h323 gateway to a partition?, (or this acheived in the form of route patterns?).
Then I can add the partition to the CSS no problem.
Ajaz
got it!
thanks
Ajaz :-)
