PRI Module in 2800
I had an early 3640 router with a PRI ISDN module in it. I've since decommisioned the 3640 and I want to put the PRI module in a 2800. However, the 2800 does not appear to recognise it. The 2800 is running c2800nm-advipservicesk9-mz.124-15.T1.bin The Cisco site appears to show that the 2800 supports a PRI ISDN module.
A "show inv" shows an unknown module in the router.
Do I need a newer version of the PRI card for my 2800 ? Is my existing one only good as a door-stop ?
Paolo Bevilacqua Fri, 09/07/2007 - 08:45
on the ISR routers, for data PRI, you can use either NM-xCE1T1 (x is the number of ports), or the VWIC-xMFT, or VWIC2-xMFT-xE1T1
With the latter hardware, support for data PRI has been added just recently and some dial features are missing. See:
http://cisco.com/en/US/products/ps6706/products_feature_guide09186a00805fe293.html
hope this helps, please rate post if it does!
