Managing VPN 3000 series devices
Sep 7th, 2007
Is there a management suite available out there from Cisco that allows to manage VPN 3000 concentrators in large enterprise networks? We would like to do a minimum configuration of the devices via their build-in CLI oder webinterface and then import them into an enterprise management solution's inventory without the need to touch the build-in interfaces again later. Everything that is beyond the basic setup (setting VPN tunnels, encryption parameters, a.s.o) should be done via the management solution in an enterprise context. Something like Cisco's Security Manager that unfortunately does not support VPN concentrators.
Thanks in advance
Thomas Schraml
didyap Thu, 09/13/2007 - 06:06
  • Silver, 250 points or more
You will have to directly use the VPN Concentrator Manager for the concentrator itself for configuring and troubleshooting. I don't think there is a management suite available to manage VPN concentrators.
