mask outbound caller-id on fxo port
Sep 7th, 2007
Is there is a way to setup a translation profile on a h323 gateway for outbound calls out the local fxo ports to be able to mask the caller-id. The customer has 3 lines which are in the rollover state by their provider. They would like for all calls that go out either 3 of the ports to display the caller-id of the main line. Is this possible with a translation rule or would they have to contact their provider to get them to mask it on their end?
Thanks!!
shane.orr Fri, 09/07/2007 - 08:36
  • Silver, 250 points or more
It is not possible manipulate outbound CLID on POTS lines from the Customer Phone System Side. In order to manipulate outbound CLID you would have to have ISDN.
You are correct, the best you could do is ask your Telco Provider if they have any type of masking capabilities but I have not seen that service. Let me know if it exists - I am going to start inquiring about it if it does.
b_ferguson Fri, 09/07/2007 - 08:42
That is what I thought, just wanted to get a second opinion on it.
Thanks for your response and if I find out anything about from the telco, I'll let you know.
