WiMax AAA using a Cisco AR 4.1
Sep 7th, 2007
I'm developing a new WiMax network and I already have a Cisco AR 4.1 AAA working on my old network. Can I use this solution to authenticate teh WiMax users also ?
Is Cisco Ar 4.1 compliant with below VSA ?
Packet-Flow Descriptor
QoS Descriptor Attrivutes
BS-ID Attribute
kdachana Wed, 09/12/2007 - 04:57
CAR WiMAX attribute support is planned in multiple phases and we are planning to complaint with WiMAX forum's Release 1.0.0 stage 3 document.
Any how if the attributes are static then it can be added directly in the CAR attribute dictionary from aregmcd under [ //localhost/Radius/Advanced/Attribute Dictionary/Vendor-Specific/Vendors ]
Hope this helps !!
marcusassis Wed, 09/12/2007 - 05:47
Thanks for replying.
Do you know if CAR supports the following attributes ?
QoS Descriptor
BS-ID
