nambi_gct Fri, 09/07/2007 - 08:47
  • Bronze, 100 points or more
yes.you can disable the spt if you want.instead i would recommend configuring spanning tree portfast on this interface.
cisco_lad2004 Fri, 09/07/2007 - 11:12
  • Gold, 750 points or more
in your case, since you are sure nobody will use this port to plug in a switch both solutions are valid. so you can either enable spanning tree portfast or disable it altogether as per nambi's post.
Sam
