input and crc errors on serial interface with integrated csu/dsu
Sep 7th, 2007
I keep getting input and crc errors on serial interface. I have changed WIC card on 2811 router and the cable connecting smart jack to the router. Other end of p2p T1 is clean. Any ideas what could be wrong?
scottmac Sat, 09/08/2007 - 05:50
  • Green, 3000 points or more
It could be a network problem.
The carrier should be able to loop & test; first to the smartjack/NIU and then to the CSU/DSU.
If the carrier still gets errors after the SJ/NIU, then the most common problems tend to be:
** Extended Demarc: If the active smartjack is some distance from the router / DSU, then it's common to put in an "extended demarc", which is just a cabling extension from the SJ/NIU to another termination near the router. Bad extended demarcs are pretty common and explain why providers can "Test OK to the SJ/NIU" and still show errors to the CSU/DSU (when the CSU/DSU is proven good).
** Cabling / Inside Wireing (IW). A variation of the extended demarc. If you have a long run from the SJ/NIU to the router/DSU, and it's not terminated well (as in properly, and "by the book" and in good condition) then it can generate all sorts of errors.
Another similar issue is that Cat{anything} cabling (UTP) is not spec for T1/DS1. There is a specific cable type ('Premises cable", now also called "T1 Cable") that is individually shielded pair inside a shielded jacket that is the true spec cable for T1.
By spec, you can go 655 feet from the SJ to the DSU .... but only on Prem cable/T1 Cable...you'll never make it (without errors) on UTP/Cat{anything}.
I know it seems odd that cabling that can carry GIgEthernet (or now, 10GigEthernet) cannot carry a simple T1 ... but the signaling is different; T1 is pure baseband pulses (noisy and subject to massive crosstalk) and Ethernet is differential signaling (less likely to interfere and be interfered with).
** Noise sources on the path. If your IW or extended demarc passes near noise sources (like motors/compressors, noisy flourescent baluns, furnaces with spark-gap ignition ...) they can interfere.
So, short story: Make sure your cabling is good, make sure it's terminated properly, if it's long, make sure it's prem cable, and make sure it's not passing noisy stuff.
Good Luck
Scott
