2800 VIC-4FXS/DID CallManager with MGCP
Sep 7th, 2007
I am provisioning a 3800 series router with VIC-4FXS/DID and want to use MGCP to connect to CallManager. The Telco is two-wire ground start so my card will supply -48V DC for signalling and Telco will ground-start my line and Touch-Tone in last 4 digits of DID number. I have 25 DID on this circuit (actually it is a group of 6 DID Tip/Ring circuits).
Is MGCP supported for this and does anyone have configuration or am I forced to use H.323 and if so same question?
Thanks. kj7radio1
kj7radio1 Fri, 09/07/2007 - 11:42
Hmmm...wrong card though wrong router. Looked at the document and is referring to VIC-DID. I have VIC-4FXS/DID. Config might work but wondering if this newer card with proper IOS would in fact support MGCP with CallManager.
jbouwkamp Fri, 09/07/2007 - 12:56
Config for the VIC-4FXS/DID in DID mode is the same as VIC-DID. MGCP does not support analog DID with either card. H323 is required.
