IOS Recommendation and feedback for NM-AIR_WLC6
Sep 7th, 2007
My company is looking at delpoying wireless in some small remote offices, we are looking at using the NM-AIR-WLC6 module in our current 2821 routers running 12.4.7d. Unfortunately our standard version of IOS doesn't support the NM. So I am looking for anyone that has deployed these modules in a 2800 series router to see what IOS you recommend. Also looking for some feed back on how the modules preform. Are you happy with them, any issues with them? Thanks in advance.
chris-marshall Mon, 09/10/2007 - 04:22
We're having good luck running the modules on 2811s with the T-train. If you're 2821 is running Call Manager Express, you'll want to be running at leasst 12.4.11(T3) or higher.
The modules are great... once they're set up, they behave exactly like a stand alone controller.
jonas2200 Fri, 05/09/2008 - 16:10
Yeah I use this one, it recognizes the WLAN-controller.
c2800nm-adventerprisek9-mz.124-15.T4.bin
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
