IPS installation help
Sep 7th, 2007
Hi All
i will install 4215 IPS sensor next week for the first time.
i will install it in inline mode between the BB switch and the internet firewall,
so i need help in smoething that :
what is configuration on the firewall and the BB switch (4507) for the sensing interfaces of the sensor????
Please find the attached file for the network diagram.
regards
Mohamed
zaidumer Wed, 09/12/2007 - 02:10
hi,
have u defined the Service group policy to define what interface will be inspected for IPS
also check if u have the virtual senson defined on the correct interface for traffic inspection..
hope it helps..
