ISSUE: EIGRP config for L3 links between 6509 and 4510R
Sep 7th, 2007
Hello Guys,
Currently I'm in the process of implementing L3 links for our campus network.
I'm having following issue with EIGRP routing.
1. 6509 core switch (L3)
2. 4510 access switch (L3 uplink /L2 access)
I have created port channels (for bandwidth aggregation) between 6500 and 4500 switch.
Issue is i'm unable to route or see the route updates from eigrp on core switch for the vlan on Access switch.
Following is the configuration from both 4500 switch and 6500 switch.
Please let me know about the missing configuration.
Cisco 4510R (Access switch) configuration
vtp domain xxx
vtp mode transparent
key chain eigrp
key 100
vlan 24-25
interface port-channel1
description link to new core1
ip address 10.211.254.42 255.255.255.252
ip authenentication mode eigrp 100 md5
ip authentication key-chain eigrp 100 eigrp
ip pim sparse-mode
logging event link-status
load-interval 30
carrier-delay msec 0
qos trust dscp
interface port-channel2
ip address 10.211.254.142 255.255.255.252
ip pim sparse-mode
load-interval 30
qos trust dscp
interface gigabitethernet 5/48
switchport access vlan 24
switchport mode access
spanning-tree portfast
interface vlan24
ip address 10.211.24.1 255.255.252.0
no ip redirects
ip pim query-interval 250 msec
ip pim sparse-mode
ip summary-address eigrp 100 10.211.24.0 255.255.252.0 5
router eigrp 100
passive-interface default
no passive-interface port-channel1
no passive-interface port-channel2
network 10.0.0.0
no auto-summary
eigrp stub connected
Switch#sh ip eigrp top
IP-EIGRP Topology Table for AS(100)/ID(10.211.1.25)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 10.211.254.40/30, 1 successors, FD is 1536
via Connected, Port-channel1
P 10.211.254.140/30, 1 successors, FD is 1536
via Connected, Port-channel2
P 10.211.24.0/22, 1 successors, FD is 2816
via Connected, Vlan24
Cisco 6509 switch (core/distribution) configuration
vtp domain xxx
ip subnet-zero
interface Port-channel1
description link to
ip address 10.211.254.41 255.255.255.252
ip pim sparse-mode
ip authentication mode eigrp 100 md5
load-interval 30
mls qos trust dscp
interface Port-channel2
ip address 10.211.254.141 255.255.255.252
ip pim sparse-mode
load-interval 30
mls qos trust dscp
router eigrp 100
network 10.0.0.0
distribute-list Default out Port-channel1
distribute-list Default out Port-channel2
no auto-summary
ip access-list standard Default
permit 0.0.0.0
permit 10.0.0.0
NEW65C1#sh ip eigrp top
IP-EIGRP Topology Table for AS(100)/ID(10.211.254.141)
umedryk Thu, 09/13/2007 - 11:06
  • Bronze, 100 points or more
These are not synchronized between the active and standby supervisors:
All Layer 3 protocols on Catalyst 4500 Series Switches (Switch Virtual Interfaces)
Cisco NonStop Forwarding (NSF) works with SSO to minimize the amount of time that a Layer 3 network is unavailable after a supervisor engine switchover by continuing to forward IP packets. The reconvergence of Layer 3 routing protocols (Border Gateway Protocol [BGP], Enhanced Interior Gateway Routing Protocol [EIGRP], Open Shortest Path First [OSPF] v2, and Intermediate System-to-Intermediate System [IS-IS]) is transparent to the user and occurs automatically in the background. The routing protocols recover routing information from neighbor devices and rebuild the Cisco Express Forwarding (CEF) table
