Traceroute behind an ASA firewall...
Sep 7th, 2007
We are a windows 2003 network and use an ASA firewall. We can trace route from the ASA device but not at our desktops...do you know the syntax we need to add this to our outside access-lists? TIA, Gary
hsajwan Fri, 09/07/2007 - 14:47
rather, you can also open complete icmp by using "permit icmp any any" on the outside interface access-list
a.alekseev Sat, 09/08/2007 - 00:10
  • Gold, 750 points or more
conf t
policy-map global_policy
class inspection_default
inspect icmp
inspect icmp error
GRANT GATHAGAN Tue, 10/02/2007 - 21:48
I still can't run traceroute through my ASA, even though it's configured as shown:
inspect icmp error
inspect icmp
service-policy global_policy global
I've issued the "clear x" command and even tried adding the following commands:
icmp permit any Outside
icmp permit any Inside
When I try "tracert yahoo.com", this is what the ASDM log shows (note that I've reversed the order to show earliest message first):
Oct 02 2007 19:26:36 302020:Built ICMP connection for faddr 66.94.234.13/0 gaddr (outside IP address) laddr (inside address)
Oct 02 2007 19:26:36 106014:Deny inbound icmp src Outside:(gateway address) dstInside:(outside IP address)(type 11,code 0)
Oct 02 2007 19:26:38 302021:Teardown ICMP connection for faddr 66.94.234.13/0 gaddr (outside IP address) laddr (inside address)
I can place a computer on the same public IP subnet that the outside interface of the ASA resides on and get traceroutes to work without issue, I know the problem lies with the ASA.
GRANT GATHAGAN Thu, 10/11/2007 - 21:45
Interestingly enough, I tried using the ACL method:
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any time-exceeded
access-group 101 in interface outside
instead of the global policy method, and that worked fine.
Go figure...
