Communication between two DMZ segments
Sep 7th, 2007
Hi friends,
I have a firewall with inside, outside + 2 DMZ's.
I am able to talk to the DMZ's from inside and outside interfaces but inter-MZ communication or communication between two DMZ's is not working.
I have all the static translations and routing in place but still it doesn't work.
I have also enabled same security traffic permit inter-interface and intra-interface. Is there any inherent limitation in ASA 5540 for this?
Thanks a lot
Gautam
gautamzone Fri, 09/07/2007 - 14:21
Just wanted to add that Syslog reports the following message for communication between two DMZ's:
%ASA-6-110001: No route to 10.0.3.10 from 10.1.20.2
Thanks a lot
acomiskey Fri, 09/07/2007 - 14:38
  • Green, 3000 points or more
Could you please post the relevant parts of the config?
gautamzone Fri, 09/07/2007 - 15:21
Sure, the configs are as follows:
no nat-control
interface GigabitEthernet1/0
nameif SA
security-level 30
ip address 10.0.3.1 255.255.255.0
interface GigabitEthernet1/2
nameif WAN
security-level 100
ip address 10.0.4.1 255.255.255.0
static (WAN,SA) 10.1.20.0 10.1.20.0 netmask 255.255.255.0
access-list SA extended permit ip any any
access-list WAN extended permit ip any any
access-list WAN extended permit icmp any any
access-group SA in interface SA
access-group WAN in interface WAN
Output of show route WAN on ASA
O IA 10.1.20.0 255.255.255.0 [110/11123] via 10.0.4.3, 0:47:31, WAN
Output of show route SA on ASA
C 10.0.3.0 255.255.255.0 is directly connected, SA
Output of show run router
router ospf 100
network 10.0.3.0 255.255.255.0 area 20
network 10.0.4.0 255.255.255.0 area 20
network 10.0.5.0 255.255.255.0 area 20
The routers 10.0.4.3 and 10.1.20.1 have OSPF advertised routes for 10.0.3.0.
Note: An interesting thing is that when i turn on capture for packets from 10.1.20.2 towards 10.0.3.10, i am seeing echo requests being sent thru but no echo replies from 10.0.3.10!!!. Also, if i ping the other way (10.0.3.10-->10.1.20.2), i am seeing echo requests being sent and echo replies being received too but firewall seems to drop them!!!
a.alekseev Sat, 09/08/2007 - 00:18
  • Gold, 750 points or more
Do you use "nat-control" or "no nat-control"?
a.alekseev Sun, 09/09/2007 - 04:29
So you needn't have static.
But another static entry in you config can break communication between two interfaces with the same security level.
