7960 line button appearances
Sep 7th, 2007
1- can you add more that three line appearences on a phone?
2- If I have six phones with two shared lines each, I want to verify that they can only recieve two calls at the same time before going to VM total.
Rob Huffman Fri, 09/07/2007 - 16:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Kevin,
On a 7960 you can have up to 6 line appearences on a single phone (check the Phone Button Template)
With Shared lines you will need to check that the "Busy Trigger" is set to 2 so that the third call will go to VM.
Hope this helps!
Rob
