Question about simulations on 640-801
Sep 8th, 2007
If anyone has asked this question already, I apologize. I'm getting ready to take 640-801 by the end of the month and my question is, when you do your simulation(s) on the test, do you have to do a "copy running-config startup-config" for it to count? Also, can we use the older "write memory" command instead?
Overall Rating: 5 (1 ratings)
kenthervey Sat, 09/08/2007 - 10:23
I passed the test(s) last week.
1. I don't know, but do it anyway.
2. I never heard of that command.
akimalijbsk8r Sat, 09/08/2007 - 19:46
Thanks for the suggestion. The next time your on a Cisco device and you update a config just do a "write memory" or "wr m". It's the precursor to "copy start run"
akimalijbsk8r Sat, 09/08/2007 - 19:50
Thanks for the suggestion. The next time you're on a Cisco device and you update a config just do a "write memory" or "wr m". It's the precursor to "copy start run"
akimalijbsk8r Sat, 09/08/2007 - 19:49
Thank you. I always use it on my practice lab at work, but wasn't sure if the tests would accept it.
