CCME with 7970
Sep 8th, 2007
Dear sir
I would like your assistance regarding CCME . I am using 2811 with (Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(11)T1) ,
I have a problem . when internal users calls to operator phone (7970) it displays only three question marks (???). but when operator pick the phone phone can diplay user name on screen. all internal users can easily see caller name on there screen or on phone display.
It was working fine before updating my new ios .
kindly tell me why three question mark on operator (??? ). how can i able to correct this problem. I am attaching show ver , show run ,show flash
your kind respomse will be highly appreciatible.
paolo bevilacqua Sat, 09/08/2007 - 04:08
  • Hall of Fame,
    Founding Member
Hi, you can try upgrading phone software to 8.2(2)SR4S, if that doesn;t help, I would reccomend using 12.4(11)XJ4 on the router that is reccomended for CME and has many many bug fixes.
Tregon Mon, 09/10/2007 - 05:35
I had a similar issue when calls connected, the number displayed on both 7970 and 7961 was garbled, e.g. D$f4Fa
If you debug the isdn q931 you can see that the message is not phone related. I created a Tac case and was provided with a special version of the IOS that corrected this bug.
paolo bevilacqua Mon, 09/10/2007 - 06:15
  • Hall of Fame,
    Founding Member
Can you say which bug id and which version you were given ?
