Task list or templates to deploy CME with CUE 2.3
Sep 8th, 2007
Dear all,
My company is prepare to deploy a Voice IP system on CME with CUE 2.3. We was leased an E1 line with 30 channels and bought a Cisco 2821 for this job. I just have a little theory and no experience about this solusion so i need a task list step-by-step to deploy such as E1 parameter for ISP do,power infrastructure (with grouding), dial plan, tftp profiles for IP Phones...which have to do first. Could anyone who has experienced share the task list or templates for me? Thanks in advance!
Overall Rating: 3.5 (2 ratings)
rob.huffman Sat, 09/08/2007 - 09:42
Hi Pham,
Here are some really good "getting started" type docs;
Cisco CallManager Express/Cisco Unity Express Configuration Example
Cisco CallManager Express 3.0 and Later Integration with Cisco Unity Express
Cisco Unified CallManager Express Solution Reference Network Design Guide
Hope this helps!
phamquoccuong Sat, 09/08/2007 - 10:04
Hi Rob,
Thanks for your helpful links! Can i have more about trunking parameter with ISP over E1?
rob.huffman Sat, 09/08/2007 - 15:02
Hi Pham,
You are most welcome! Here is a little more information, you will need to determine what E1 Interface module to use what DSP resources are needed etc;
Second-Generation 1- and 2-Port T1/E1 Multiflex Trunk Voice/WAN Interface Cards
IP Communications High-Density Digital Voice/Fax Network Module
Cisco 2800 Series Integrated Services Routers Quick Start Guide
Cisco IPC Express System Configuration Example
Hope this helps!
Please remember to rate helpful posts.....
Paolo Bevilacqua Sat, 09/08/2007 - 15:33
I guess what Phan wants to know is how to configure the "E1". For this one would need to know first: Is it ISDN PRI (hopefully) ? Have you got DID service from telco ? If yes for how many digits ? Do you want outgoing calls to present the main number or individual extension as CLID ? And few more questions perhaps.
I'm thinking of writing a practical guide on this subject alone.
phamquoccuong Sun, 09/09/2007 - 03:51
Yes, your suggests are the things i need to got to recieved or request our Telco provides. And abount the main number or individual ext, i should be plan this because i was not thinking about that before.
Paolo Bevilacqua Sun, 09/09/2007 - 08:33
I will give you an advice that is not in any book. If possible, assign extensions starting with a digita that is not used in your contry dialplan.
For example, if landlines number all begins with 4, an cellphones with 3, assign extensions starting with 2 followed by 2 or 3 more digits.
This will allow to make outgoing calls without any prefix digits, thing that not only makes calling faster, but also makes it easier to call-back and click-to-dial.
phamquoccuong Sun, 09/09/2007 - 03:40
Hi Rob,
I found many infomation relate to my case included links you sent for me. I must to focus the main element. Many options will customize in future. I will see the links you gave to getting start. Thanks!
