IP access-class question
Sep 8th, 2007
Good morning all. I have SwitchA (2950) and SwitchB (2950) connected via crossover. VLAN1 configs are as follows...
SwitchA - ip add 192.168.1.1/30
SwitchB - ip add 192.168.1.2/30
ip add 10.7.10.152/24 sec
SwitchA has the following access-list configured
access-list 1 permit host 10.7.10.152
ip access-class vty 0 15 in
When I try to telnet to SwitchA from SwitchB, I get denied. I used the following command
192.168.1.1 /source-interface vlan1
Is there a way to force telnet to use secondary ip address as the source instead of the interface to bypass the access-class block?
Edison Ortiz Sat, 09/08/2007 - 20:29
  • Hall of Fame,
    Founding Member
No, you can't source from a secondary ip address when using the source-interface option within telnet.
I don't have a 2950 at the moment to test, but instead of creating a secondary IP address on Vlan1, can you create a loopback ?
akimalijbsk8r Sat, 09/08/2007 - 22:07
Thanks for that clarification. I'll have to try the loopback solution next week. Thanks again.
Richard Burts Sun, 09/09/2007 - 13:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Akim
The 2950 switch is a layer 2 switch and as such I believe that it does not support the concept of loopback interface.
also I note that the syntax in your post is incorrect. Instead of this:
you would need this:
line vty 0 15
access-class 1 in
If you are trying to telnet from 1 layer 2 switch to another layer 2 switch I do not believe that you will be able to use secondary addressing.
I am not clear why you are attempting to use secondary addressing in this. If you want to permit one layer 2 switch to telnet to the other layer 2 switch why not just permit its management interface? Perhaps if you explain your environment and what you are trying to accomplish we might be able to help find a way to achieve it.
Rick
akimalijbsk8r Sun, 09/09/2007 - 20:05
Rick,
Thanks for catching my error in syntax. I did input it correctly in my lab though. There is/was no particular need for me doing that. The environment is stictly a lab (3 routers and 3 switches) and I was just playing with the access-class command. Was just curious if it could be done. Thanks for the reply! (I learn more from these forums than I would've thought!)
Akim
