IOS!!!
Sep 8th, 2007
Hi All,
I would like to upgrademy voice gaetway router 3745 IOS to c3745-ipvoicek9-mz.124-16.bin (30 MB)
Is it OK to upgrade to above IOS?
My current IOS and memory details is below:
VG#show version
IOS (tm) 3700 Software (C3745-IPVOICE-M), Version 12.3(12), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 29-Nov-04 14:49 by kellythw
Image text-base: 0x60008AF4, data-base: 0x619C0000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
ROM: 3700 Software (C3745-IPVOICE-M), Version 12.3(12), RELEASE SOFTWARE (fc3)
VG uptime is 1 day, 11 hours, 59 minutes
System returned to ROM by reload at 18:33:39 UTC Sun Mar 14 1993
System image file is "flash:c3745-ipvoice-mz.123-12.bin"
cisco 3745 (R7000) processor (revision 2.0) with 247808K/14336K bytes of memory.
Processor board ID JPE084710B0
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
48 Serial network interface(s)
4 Channelized T1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31360K bytes of ATA System CompactFlash (Read/Write)
VG#dir
Directory of flash:/
1 -rw- 18249024 Mar 11 2002 01:25:26 +09:00 c3745-ipvoice-mz.123-12.bin
31936512 bytes total (13684736 bytes free)
VG#
paolo bevilacqua Sun, 09/09/2007 - 08:38
  • Hall of Fame,
    Founding Member
Yes, it should be fine.
Joseph W. Doherty Sun, 09/09/2007 - 16:13
If you're happy with the feature set of your current IOS, i.e. there isn't some 12.4 feature you "must have", you might also consider just updating to the latest 12.3 version since it's GD and 12.4 isn't (yet).
