Troubleshooting Sims in CCNA 640-801
Sep 9th, 2007
In a troubleshooting sim question in CCNA 640-801 do you have to enter ping commands to the various interfaces and run sh ip route etc to verify answer is correct, or will you just get the same marks if you just press Next button, if confident you have found the solution (ie save time by not testing it). Ie does it test you for entering the pings, or other test commands ?
