tstanik Fri, 09/14/2007 - 11:50
The problem is most probably in your vpn client installation. You should uninstall and then reinstall the vpn client. Also check if there are any other services that are conflicting with the vpn client when a tunnel is initaited. If you have firewall installed try connecting to the vpn3000 server by disabling the firewall.
marchmilan Fri, 09/14/2007 - 21:26
thanks
and I try use splittunnel and network list in the vpn3000
