CCNP WorkBook
Sep 9th, 2007
Hi;
Kindly could you Advice which is the Best Workbook That I can Download it or buy it if it's require.
Since I complete My CCNP Self Study & I used the Remote Labs on Cisco E-Learning but Now I am looking to work with Cisco Rack rental to do that I need to have workbook otherwise it will be useless.
& If you know The Cisco Rack Rental compatible with the Work Book it will be helpful.
