Why VPLS and not L3 VPNs ???
Sep 9th, 2007
Hi all
Please bare with me, i know a lot has been written about what VPLS is, I have read the postings, but maybe someone can in simple terms answer my qn for me;
Why should one go for VPLS and not L3 VPNs or L3 VPNs and not VPLS, i need arguments from both the enterprise point and the ISP point
Hope you get my Question
MM
Overall Rating: 4 (1 ratings)
Well..
VPLS:
+No need to involve the ISP for routing issues
+Support non-IP protocols - IPX, AppleTalk etc..
-Difficult to troubleshoot
-Possible to make a L2-loop
-Customers could overflow mac-tables.
L3-VPN:
+ISP control the routing process - or the customer could control the CE-PE, and control it's own routing.
+Loops are avoided with routing-protocols
-Non-IP protocols have to be encapsulated to work
Personally I liked the VPLS best before, but after choosing an ISP supporting PE-CE-protocols, not using static's and has a good support centre, I always recommend L3VPN's.
Also within our own MPLS-network we always use L3. (with no 7600's VPLS is not supported...) EoMPLS is not used permanently used within out MPLS, but could be used for moving a customer from one datacenter to another, or other special timelimited purpose...
[email protected]
mmrrittner Tue, 09/11/2007 - 04:28
hello,
VPLS built easy cluster?s for data center in different locations. easy migration, outsourcing for datacenter etc.
regards
michael
