pix arp timeout
Sep 9th, 2007
hi netpros,
customer is running a pix behind some loadbalancing facility in ha mode which when failover occurs changes its mac address. no gratious arp is sent.
so pix is not reachable for 4 hours becaude of standard arp time out of the pix.
so my question is, whats a good timeout here. 5 min should not be a problem?
red in this forum that the timeout should not be less than 60s?!
whats your preferred timeout ;-)
thanks in advance.
juergen
a.alekseev Sun, 09/09/2007 - 13:37
Default is good :))
but in your case the timeout should be time acceptable for failover.
If 5 min is ok for you let it be 5 min.
In any case you should monitor CPU load before and after arp timeout modifications.
