2811 Router with Vlan and NAT
Sep 9th, 2007
Hi All,
Would appreciate a reply for the following scenario. I have an IPT environment with 3 dot1q vlans on a 3560 switch...infrastructure vlan 10 (, voice vlan 20(, data vlan 30( The switch is connected to a 2811 fast ethernet port. My question is, if I am receiving just 1 IP (192.1.1.x) for the internet connection to the 2811 router, how do I configure the fast ethernet port for nat and also for the individual vlans that are connecting to it. Would the static routes be advisable for the connection to the vlans? Any recommendations are appreciated!
Thanks guys
Jon Marshall Sun, 09/09/2007 - 22:50
Not 100% sure what you are asking. Do you mean you have one public IP address allocated to the outside interface of your 2811 router ?
Assuming this is what you mean you can setup NAT as follows
(Assume interface with your public IP address is fa0/1)
access-list 101 permit ip any
ip nat inside source list 101 interface fa0/1 overload
int fa0/0
ip nat inside
int fa0/1
ip nat outside
tomtom001 Mon, 09/10/2007 - 04:38
Thank you for the reply Jon. Yes, I have 1 Public IP address coming from a T1 data connection. The outside interface would be the serial associated with the T1 connection. For the inside interface, do I need to create subinterfaces for each vlan?
For example:
int fa0/0.1 for infrastruture
description ***infrastructure Vlan***
encapsulation dot1Q 10
ip address
ip nat inside
etc...for fa0/0.2 and fa0/0.3
I appreciate the help!
mahmoodmkl Mon, 09/10/2007 - 04:46
yes u need to create sub-interfaces in order to enable routing between the vlans.
tomtom001 Mon, 09/10/2007 - 11:16
Thank you for the info.
Can you offer suggestions for my static routes for the ISP and the subinterfaces?
I almost have the understanding of how it all connects.
