OSPF routers in numbered serial link
Sep 9th, 2007
Hi all,
When OSPF routers are connected in numbered serial link, why the router LSA shows two links for that connection. One as 'Connected to another router (point-point)' and another as "Connected to stub network'. Is it same if they are in multi access network ?
Vijaybabu
Overall Rating: 3 (1 ratings)
etienne.basset Sun, 09/09/2007 - 23:46
hello,
it's rfc (2328) expected behaviour :
basically, the point2point link is used for topology but doesn't have the IP/mask info that is in the stub network link
Etienne
quoting "http://www.ietf.org/rfc/rfc2328.txt"
For point-to-point interfaces, one or more link
descriptions are added to the router-LSA as follows:
o If the neighboring router is fully adjacent, add a
Type 1 link (point-to-point). The Link ID should be
set to the Router ID of the neighboring router. For
numbered point-to-point networks, the Link Data
should specify the IP interface address. For
unnumbered point-to-point networks, the Link Data
field should specify the interface's MIB-II [Ref8]
ifIndex value. The cost should be set to the output
cost of the point-to-point interface.
o In addition, as long as the state of the interface
is "Point-to-Point" (and regardless of the
neighboring router state), a Type 3 link (stub
network) should be added. There are two forms that
this stub link can take:
Option 1
Assuming that the neighboring router's IP
address is known, set the Link ID of the Type 3
link to the neighbor's IP address, the Link Data
to the mask 0xffffffff (indicating a host
route), and the cost to the interface's
configured output cost.[15]
Option 2
If a subnet has been assigned to the point-to-
point link, set the Link ID of the Type 3 link
to the subnet's IP address, the Link Data to the
subnet's mask, and the cost to the interface's
configured output cost.[16]
GillieLucent Mon, 09/10/2007 - 00:22
Thanks for the info.
But whats the use of it ?
Vijaybabu
etienne.basset Mon, 09/10/2007 - 00:46
hello
that's because of the router lsa format :
for the p2p link type, linkid is set to the neighbor routerid (used for building the net topology). There's not enough room in the link data (32bits) to store IP+mask of the p2p link thus the need for another link (stub)
well, that's how i understand this ;)
regards
etienne
