GRE Tunnel
Answered Question
Sep 9th, 2007
Can I expand the BW of my tunnel? How? I only have 9 KBit. I think this is the default. Am I right? Please advice on what will I do.
Tnx a lot!!!
Correct Answer by tdrais about 9 years 10 months ago
The bandwidth does not affect the speed data is transferred over a interface and that is all interfaces not just tunnels.
It is basically just a number and you can set it to anything you want. The true transfer rates are set by the physical clocks on a interface.
You will always send/receive data at the interface rate even if you leave the bandwidth set to 9k
This parameter is used
1. By some routing protocols to select path. This needs to be set correctly for the router to be able to select the proper "best" path. Be careful running routing protocols over a tunnel you must avoid learning the tunnel end points over the tunnel.
2. QoS For a tunnel it is of limited use to run QoS but in some cases where you want to limit the traffic it can be effect to apply QoS to a tunnel.
3. Many monitor tools read this value via SNMP. Mostly this stops calls in the middle of the night from your NOC guys worried because their tool said the tunnels was utilized 3000%
Using tunnels to run routing over MPLS is one of the more common uses lately. You really won't have a issue leaving it at 9k as long as you leave all your tunnels at 9k. Just be consitant but it is best practice to set it to the physical interface speed.
In your case this is the simple way to run routing over a MPLS network. You can do what you want without involving your provider. If you have many sites with any to any conectivity it gets complex to maintain all the tunnels and you are better off running BGP directly with your provider. Once the BGP is setup you have a lot control over routing within the cloud but still not to the level tunnels allow. All depends on how large a MPLS network you have.
Overall Rating: 5 (3 ratings)
lgijssel Mon, 09/10/2007 - 01:40
  • Red, 2250 points or more
Default bandwidth for a GRE tunnel is 9k indeed.
You can adjust this to match the bandwidth that is actually available using the "bandwidth" command.
regards,
Leo
cmadiam82 Mon, 09/10/2007 - 17:22
If I increase the bandwidth to the original value, am I using the exact value of the bandwidth? or still I'm only using 9Kb of that connection? example: I have a 256Kb of connection. We have a network using MPLS/VPN. We created this tunnels so that we can use EIGRP for routing. Is there any other suggestions in such a way that we can use dynamic routing instead of static?
Tnx a lot!
Correct Answer
tdrais Mon, 09/10/2007 - 18:17
  • Blue, 1500 points or more
cmadiam82 Mon, 09/10/2007 - 19:14
tnk u tdrais. this will help me a lot. im just beginning to learn Cisco networks. du u have any IM id? maybe if you have some free time, we can chat. i have so many questions in mind that needs to be answered. right now, im planning to use our L3 switch and config it for L3 routing. maybe u can help me on this one. tnx again. hope to hir from u soon. this is my id in yahoo. [email protected]
regards,
chester
