Which ASDM version for FWSM 3.1(4.0)?
Sep 9th, 2007
Hi Sir,
I'm upgrading an FWSM from version 2.3(3) to the Safe Harbor certified version 3.1(4.0).
Release Notes of 3.1(4.0) mentions that ASDM release 5.0F supports FWSM software release 3.1 features.
I checked Software Downloads; the latest 5.0F version is 5.0(3)F. I also noticed the latest version 5.2(2)F is available for FWSM 3.1 and 3.2. Can I use the latter version?
Please advise.
Thank you.
B.Rgds,
Lim TS
tstanik Fri, 09/14/2007 - 12:31
  • Bronze, 100 points or more
Yes, you can use the ASDM version 5.2(2)F for your FWSM. Version 5.2(2) will be better compared to the other version and may have a few more features also.
