E0 line up, protocol down
frederikd
Need urgent help/suggestions - how can i get the E0 protocol up again
show ip int brief output
se0 line up, protocol up
e0 line up, protocol down
the e0 interface connect to a switch with a rj45 connection
Jon Marshall
Check
1) The cable and that is connected properly at both ends.
2) The switch port has been enabled and is not in shutdown mode.
3) The speed and duplex settings. Either set both ports to be auto/auto or hardcode the same settings on either end.
Jon
